Just to add to this a bit…if you’re going to use this generically, I’d encourage using the “tuple string of” inspector instead of ‘concatenation ", " of’. Because ‘tuple string’ will handle cases where the strings already have embedded commas, by escaping them in a way that ‘tuple string items’ recognizes.
q: ("To be, or not to be, that is the question:"; "Whether 'tis nobler in the mind to suffer"; "The slings and arrows of outrageous fortune,")
A: To be, or not to be, that is the question:
A: Whether 'tis nobler in the mind to suffer
A: The slings and arrows of outrageous fortune,
T: 0.611 ms
I: plural string
q: tuple string of ("To be, or not to be, that is the question:"; "Whether 'tis nobler in the mind to suffer"; "The slings and arrows of outrageous fortune,")
A: ( To be, or not to be, that is the question: ), Whether 'tis nobler in the mind to suffer, ( The slings and arrows of outrageous fortune, )
T: 0.576 ms
I: singular string
q: tuple string item 0 of tuple string of ("To be, or not to be, that is the question:"; "Whether 'tis nobler in the mind to suffer"; "The slings and arrows of outrageous fortune,")
T: 0.495 ms
I: singular string
q: tuple string item (number of tuple string items of it - 1) of tuple string of ("To be, or not to be, that is the question:"; "Whether 'tis nobler in the mind to suffer"; "The slings and arrows of outrageous fortune,")
T: 0.409 ms
I: singular string
In the Services list above, I think the alphabetical order is not guaranteed…I think the inspector is retrieving the services in order of service name while you are retrieving the display name of the services, so in many cases the order is the same; I think the “Intel SGX AESM” service probably has an internal service name of “AEMS” and hence was sorted between Adobe and Alljoyn. But to guarantee a sorted order we can use ‘unique values of (string)’.
q: unique values of ("To be, or not to be, that is the question:"; "Whether 'tis nobler in the mind to suffer"; "The slings and arrows of outrageous fortune,")
T: 0.290 ms
I: plural string with multiplicity
Combining the two, we can guarantee retrieving the last string in sorted alphabetical order
q: tuple string item (number of tuple string items of it - 1) of tuple string of unique values of ("To be, or not to be, that is the question:"; "Whether 'tis nobler in the mind to suffer"; "The slings and arrows of outrageous fortune,")
T: 0.173 ms
I: singular string
