This relevance is supposed to return TRUE if the computer is a member of a particular group. The computer group ID is 00-3228333, and the custom site that the group is in is called ‘Data Center (WIN)’
Relevance:
(exists true whose (if true then (member of group 3228333 of sites whose (name of it = “Data Center (WIN)”)) else false))
In the fixlet debugger, it shows an ‘eval error’ failure on the ‘group 3228333’ section.
Any thoughts as to what is wrong with my relevance?
If you want an easier way to just validate the logic, if you have access to the Thick console you can go to computer groups and create a new automatic group, then put the logic for Group Membership “is member of” ______
Then when you go to the Description tab of the computer group it will give you the Relevance that it created for that computer group and site. If you are not going to use the group, I would recommend deleting it so that you don’t have a lot of extra Computer groups though.
