I have created an analyses for total size of each drive but for few of the system I’m getting an error: Singular expression refer to non-existent object
Code used for Total size of each Drive
(name of it & " - " & (total space of it / 1024 / 1024 /1024) as string & "GB") of drives whose (type of it = "DRIVE_FIXED")
For the few system which is fetching data as Singular expression refer to non-existent object.I took the RDC and checked that all the system is having “Local Disk Q:\ Access Denied; 0 Bytes; File System: [Blank]”.
A “Q:” disk is probably a Microsoft AppV disk and is hidden.
You could probably do this:
((name of it & " - " & (total space of it / 1024 / 1024 /1024) as string & "GB") | (name of it & " - Error")) of drives whose (type of it = "DRIVE_FIXED")
EDIT: probably just use JGStew’s answer – this is only applicable if you want to know about the Q drive and not just filter it out.
You need to just retrieve the numerical sizes of the disks (no text modifiers such as ‘GB’). Having that raw data you can simply sum them
q: total spaces of drives whose (type of it = "DRIVE_FIXED")
A: 254214393856
A: 500106784768
T: 0.731 ms
I: plural integer
q: sum of total spaces of drives whose (type of it = "DRIVE_FIXED")
A: 754321178624
T: 0.372 ms
I: singular integer
