I was trying to create a task to deploy Java patches on a Solaris box, and I used the Solaris Patch Deployment Wizard. The relevance that was generated wasn’t what I was expecting:
exists pkgdb AND (not exists patch "118666" of it OR greatest revision of patch "118666" of it < "86") of pkgdb
To me, the above looks like it is saying:
Make sure pkgdb exists and if it does, check the following:
If patch 118666 doesn’t exist, install the patch
If 118666 exists, install the patch if the highest revision of patch 118666 is less than 86.
What I was expecting was:
exists pkgdb AND (exists patch "118666" of it AND greatest revision of patch "118666" of it < "86") of pkgdb
If patch 118666 doesn’t exist, don’t install the patch (if it wasn’t installed, don’t install it now)
Maybe it’s just a preference, but I was expecting 118666-86 to only be installed if a previous version of this patch was already present on the target machine.
Maybe using a Java Patch, this is the way it should be implemented, but for other patches, it should be installed it if is not currently on the system?
Thanks,
Bob_K
