We are using _BESClient_Resource_SleepIdle/Workidle
for BESClient but looking for something if there is any setting which control Relay CPU.
I know above setting nothing to do with Relay but just want to check if there is anything. And how relay CPU is being used for Relay services ? Can we increase/decrease CPU for Relay also ?
There’s not much CPU needed for the relay service. Relays are more reliant on bandwidth and disk i/o. There are certainly things that can be tuned for more efficient relays, but CPU is not (if I recall correctly) one of them.
Ha e you read the Capacity and Planning Guide ? Search for that term, here in the forum, and read that document, it has all the tuning.
