system
July 24, 2007, 8:18pm
1
(imported topic written by mcalvi91)
We are creating a fixlet to fix a problem with our windows agent GUIDs. When we try to delete the GUID using the following actionscript, the log shows it as a success, but the reg value stays in the registry.
regdelete "
HKLM\SOFTWARE\Network Associates\ePolicy Orchestrator\Agent
" “AgentGUID”
any help would be appreciated.
system
July 24, 2007, 8:25pm
2
Hi mcalvi,
I don’t think you can use the HKLM shortcut with the regdelete action. Try using the full string ‘HKEY_LOCAL_MACHINE’.
Alternatively, we like to use .reg files to manipulate the registry. They are a little easier to work with most of the time.
delete __appendfile
delete temp.reg
appendfile REGEDIT4
appendfile [-HKEY_LOCAL_MACHINE\SOFTWARE\Network Associates\ePolicy Orchestrator\Agent\AgentGUID]
move __appendfile temp.reg
wait regedit -s temp.reg
system
July 24, 2007, 8:30pm
3
expanding the HKLM -> HKEY_LOCAL_MACHINE did the trick… thanks!
