Hi @Jayfry ,
In my case the DWORD value is different like below,
key= BOH_Service and value=0x00000050(1),
If I use the relevance like below mean, I can get value as true. But If I use the string value "(name of it = “UserList” AND value “BOH_Service” of it as string as version = “50”) " mean it is showing false
exists key whose (name of it = “UserList” AND value “BOH_Service” of it as string as version = “1”) of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts” of native registry
Is there any other option to modify and get the validation as value 50 Instead of 1?
Thanks,
Nagaraj.
That…doesn’t make sense to me.
value=0x00000050(1) - this should be indicating the hexadecimal and decimal values. i.e. the 0x00000050 is a hexadecimal value equal to decimal value 80.
I’m not sure exactly what you’re seeing, can you post a screenshot of what you’re looking for?
Hi @JasonWalker
The actual value look like below
value=0x00000048(72)
Thanks,
Nagaraj.
Please share registry key - HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts\UserList
As I understand from the following documentation - https://superuser.com/questions/1365614/hide-administrator-account-from-windows-login-screen -you are trying to look for computers which decided to hide user - BOH_Service, am I correct?
I don’t have those keys on my system but I think you could try some of the following as references:
q: 72 as hexadecimal
A: 48
T: 0.236 ms
I: singular string
q: 72 as hexadecimal = "48"
A: True
T: 0.196 ms
I: singular boolean
q: exists values "BOH_Service" whose (it as integer = 72) of keys "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts\UserList" of native registry
A: False
T: 0.151 ms
I: singular boolean
q: exists values "BOH_Service" whose (it as integer as hexadecimal = "48") of keys "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\SpecialAccounts\UserList" of native registry
A: False
T: 0.063 ms
I: singular boolean
Hi @orbiton
Thanks for your updates and response and the actual Registry key is under below path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\
But the value showing as hexadecimal, so I was tried @JasonWalker relevance and it is good for me as I expected results.
Nagaraj.
