(imported topic written by RichB91)
Please keep in mind when you look at this code and wonder what good it does, that it is just for an example of a problem. All the code that doesn’t relate directly to the problem has been removed to make it much more readable.
There are two tasks that get put in to a baseline. One task manages actions before the reboot and the other, not surprisingly, handles the post-reboot actions.
To manage a challenge we have around some servers not rebooting properly, we’re logging the current time to a temporary file just before issuing the
Restart 5
command and then, after the reboot, the 2nd task is supposed to read that value from the temp file and uses
((Now - Uptime of Operating System) > (Line of File (Parameter " LogPathFile")) as Time)
to confirm that the reboot completed in the expected window.
Test Version 1
When the tasks are run in the Fixlet Debugger’s Action tab, and I cancel the reboot (so I can actually copy the contents of the output in the Client Log sub-tab),
color=green
everything works as expected[/color].
Test Version 2
When I comment out the
// Restart 5
in the Pre-Reboot task and then run the two tasks as a single baseline from the BES console,
color=green
Test Version 3
When I run the two tasks as a single baseline from the BES console, and let the
Restart 5
actually reboot the test system, I get a
color=red
Relevance substitution failed[/color] error.
Primary Question
Why does this work both in the Fixlet Debugger, and as a Baseline when the Restart 5 is skipped, but not as a Baseline when the Restart 5 is included?
Text of Pre-Reboot Task
color=blue
// Pre-Reboot Task
Continue If {name of operating system as string as lowercase contains “win”}
Parameter “LogPathFile” = “C:\Temp\RebootTimeStamp.txt”
Delete __appendfile
Delete {Parameter “LogPathFile”}
Appendfile {Now}
Copy __Appendfile {Parameter “LogPathFile”}
Restart 5[/color]
Text of Post-Reboot Task
color=blue
// Post-Reboot Task
Continue If {Exists File (Parameter “LogPathFile”)}
Parameter “RebootTime” = “{Line of File (Parameter “LogPathFile”)}”
If {((Now - Uptime of Operating System) > (Line of File (Parameter “LogPathFile”)) as Time)}
Parameter “OKToProceed” = “Yes”
Else
Parameter “OKToProceed” = “No”
EndIf[/color]
Output to Client Log sub-tab of Action tab of Fixlet Debugger
—Pre-Reboot Task – When prompted “Are you sure you want to restart?�� I click No.
STATUS: Running action…
Command succeeded (evaluated true) continue if {name of operating system as string as lowercase contains “win”}
Command succeeded parameter “LogPathFile” = “C:\Temp\RebootTimeStamp.txt”
Command succeeded delete __appendfile
Command succeeded delete C:\Temp\RebootTimeStamp.txt
Command succeeded appendfile {Now}
Command succeeded (file created) appendfile Wed, 22 Dec 2010 14:45:07 -0500
Command succeeded appendfile Wed, 22 Dec 2010 14:45:07 -0500
Command succeeded copy __Appendfile C:\Temp\RebootTimeStamp.txt
- Result —
Evaluation completed successfully!
—Post-Reboot Task
Command succeeded (evaluated true) continue if {Exists File (Parameter “LogPathFile”)}
color=green
Command succeeded parameter “RebootTime” = “Wed, 22 Dec 2010 14:45:07 -0500”[/color]
Command succeeded parameter “OKToProceed” = “No”
- Result —
Output to C:\Program Files\BigFix Enterprise\BES Client__BESData__Global\Logs\20101222.log when // Restart 5 is commented out.
At 14:59:39 -0500 - opsite193 (http://mercury.
companyname
.com:52311/cgi-bin/bfgather.exe/opsite193)
Relevant - (fixlet:148435)
Relevant - TEST: Read file after reboot part 1 (fixlet:148436)
At 14:59:46 -0500 -
Report posted successfully.
At 14:59:49 -0500 - opsite193 (http://mercury.
companyname
Relevant - TEST: Read file after reboot part 2 (fixlet:148437)
At 14:59:49 -0500 -
ActionLogMessage: (action 148435 ) Action signature verified
ActionLogMessage: (action 148435 ) starting group action
ActionLogMessage: (action 148436 ) starting sub action
At 14:59:50 -0500 - actionsite (http://mercury.
companyname
.com:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded (evaluated true) continue if {name of operating system as string as lowercase contains “win”} (fixlet 148436)
Command succeeded parameter “LogPathFile” = “C:\Temp\RebootTimeStamp.txt” (fixlet 148436)
Command succeeded delete __appendfile (fixlet 148436)
Command failed (File not found) delete C:\Temp\RebootTimeStamp.txt (fixlet 148436)
Command succeeded appendfile {Now} (fixlet 148436)
Command succeeded (file created) appendfile Wed, 22 Dec 2010 14:59:50 -0500 (fixlet 148436)
Command succeeded appendfile Wed, 22 Dec 2010 14:59:50 -0500 (fixlet 148436)
Command succeeded copy __Appendfile C:\Temp\RebootTimeStamp.txt (fixlet 148436)
At 14:59:50 -0500 -
ActionLogMessage: (action 148436 ) ending sub action
At 14:59:50 -0500 - opsite193 (http://mercury.
companyname
Not Relevant - TEST: Read file after reboot part 1 (fixlet:148436)
At 14:59:52 -0500 -
ActionLogMessage: (action 148437 ) starting sub action
At 14:59:53 -0500 - actionsite (http://mercury.
companyname
Command succeeded (evaluated true) continue if {name of operating system as string as lowercase contains “win”} (fixlet 148437)
Command succeeded parameter “LogPathFile” = “C:\Temp\RebootTimeStamp.txt” (fixlet 148437)
Command succeeded (evaluated true) continue if {Exists File (Parameter “LogPathFile”)} (fixlet 148437)
color=green
Command succeeded parameter “RebootTime” = “Wed, 22 Dec 2010 14:59:50 -0500” (fixlet 148437)[/color]
Command succeeded parameter “OKToProceed” = “No” (fixlet 148437)
At 14:59:53 -0500 -
ActionLogMessage: (action 148437 ) ending sub action
Output to C:\Program Files\BigFix Enterprise\BES Client__BESData__Global\Logs\20101222.log when Restart 5 is allowed to actually reboot the test machine.
At 15:50:50 -0500 - opsite193 (http://mercury.
companyname
Relevant - (fixlet:148459)
Relevant - TEST: Read file after reboot part 1 (fixlet:148460)
At 15:50:59 -0500 -
At 15:51:03 -0500 - opsite193 (http://mercury.
companyname
Relevant - TEST: Read file after reboot part 2 (fixlet:148461)
At 15:51:03 -0500 -
ActionLogMessage: (action 148459 ) Action signature verified
ActionLogMessage: (action 148459 ) starting group action
ActionLogMessage: (action 148460 ) starting sub action
At 15:51:04 -0500 - actionsite (http://mercury.
companyname
Command succeeded (evaluated true) continue if {name of operating system as string as lowercase contains “win”} (fixlet 148460)
Command succeeded parameter “LogPathFile” = “C:\Temp\RebootTimeStamp.txt” (fixlet 148460)
Command succeeded delete __appendfile (fixlet 148460)
Command succeeded delete C:\Temp\RebootTimeStamp.txt (fixlet 148460)
Command succeeded appendfile {Now} (fixlet 148460)
Command succeeded (file created) appendfile Wed, 22 Dec 2010 15:51:04 -0500 (fixlet 148460)
Command succeeded appendfile Wed, 22 Dec 2010 15:51:04 -0500 (fixlet 148460)
Command succeeded copy __Appendfile C:\Temp\RebootTimeStamp.txt (fixlet 148460)
At 15:51:04 -0500 -
ActionLogMessage: (action 148460 ) ending sub action
At 15:55:18 -0500 -
ActionLogMessage: (action 148461 ) starting sub action
At 15:55:23 -0500 - actionsite (http://mercury.
companyname
Command succeeded (evaluated true) continue if {name of operating system as string as lowercase contains “win”} (fixlet 148461)
Command succeeded parameter “LogPathFile” = “C:\Temp\RebootTimeStamp.txt” (fixlet 148461)
Command succeeded (evaluated true) continue if {Exists File (Parameter “LogPathFile”)} (fixlet 148461)
At 15:55:24 -0500 - actionsite (http://mercury.
companyname
color=red
Command failed (Relevance substitution failed) parameter “RebootTime” = “{Line of File (Parameter “LogPathFile”)}” (fixlet 148461)[/color]
At 15:55:25 -0500 -
ActionLogMessage: (action 148461 ) ending sub action
At 15:55:29 -0500 -
ActionLogMessage: (action 148459 ) ending group action (completed)
