(imported topic written by LuisTorres)
hello
I’m trying to install on some machines but CPM and some tell me that the action is unsuccessful, in the action information I can see that the error is always on the same line
Fail waithidden “{download path “TMCPMInstaller.exe”}” -f “multi-language” -i “{name of drive of system folder & “” & following text of last “” of value of variable “ProgramFiles” of environment & “\Trend Micro”}”
Completado
// action script to deploy CPM Endpoint application
Completado
begin prefetch block
Completado
if {((name of it as lowercase = “win8.1” or name of it as lowercase = “win2012r2”) of (operating system))}
Completado
if {x64 of operating system}
Completado
add prefetch item name=TMCPMInstaller.exe sha1=6fb79a5da6fcfb9407638d245967302db782c20c size=131754009 url=http://esp-download.trendmicro.com/download/cpm/TMCPMInstaller_x64_10.6.0.3021_en.exe
Completado
else
Completado
// add prefetch item for 32-bit installer
Completado
add prefetch item name=TMCPMInstaller.exe sha1=ff7e15bdd316fb2faed685a60facd20ec5085315 size=114466116 url=http://esp-download.trendmicro.com/download/cpm/TMCPMInstaller_x86_10.6.0.3021_en.exe
Completado
endif
Completado
else
Completado
Completado
add prefetch item name=TMCPMInstaller.exe sha1=2034f356a8a2f18c0af7799ec63bbc10dfa0485b size=131720166 url=http://esp-download.trendmicro.com/download/cpm/TMCPMInstaller_x64_10.6.0.3014_en.exe
Completado
else
Completado
Completado
add prefetch item name=TMCPMInstaller.exe sha1=6bebc7cd3e2de6e619d08d4984a907efd7fcad54 size=114434959 url=http://esp-download.trendmicro.com/download/cpm/TMCPMInstaller_x86_10.6.0.3014_en.exe
Completado
endif
Completado
endif
Completado
end prefetch block
Completado
// specify custom install path
Completado
action parameter query “install_path” with description “Specify an installation path%0A%0AFor default installation path, leave blank”
Completado
// *** CHECK *** Action fails here if install path contains %environment_variables% OR illegal characters " ? * | / < > and :
Completado
// OR if the path has no drive letter specified, i.e. “\folder1\folder2”
Completado
continue if {(if (it = “”) then (true) else ((not exists matches (regular expression “[%25%22?|/<>:]") of it) of ((parenthesized part 3 of matches (regular expression "^(\w+):(\)?(.)$”) of it) as string) of (if (it starts with “%22” AND it ends with “%22”) then ((preceding text of position (length of it - 1) of it) of (following text of position 1 of it) of it) else (it)))) of ((parameter “install_path” of action) as string)}
Completado
// *** CHECK *** Action fails here if default install path ("") OR custom install path does not contain a valid drive that meets minimum 700 MB space requirement
Completado
continue if {(if (it = “”) then (exists it whose (type of it = “DRIVE_FIXED” AND free space of it >= 70010241024) of (drive of parent folder of client)) else (if (exists parenthesized part 2 of matches (regular expression “^(%22)?(\w):”) of it) then ((exists drive it whose (type of it = “DRIVE_FIXED” AND free space of it >= 70010241024)) of ((parenthesized part 2 of matches (regular expression “^(%22)?(\w):”) of it as string) & “:”)) else (false))) of ((parameter “install_path” of action) as string)}
Completado
//delete CPMInstallResult.log
Completado
delete “{pathname of windows folder}\CPMInstallResult.log”
Completado
//rename temp file(if exist) at SYSTEMDRIVE before running installer
Completado
if {exist file ((value of variable “SYSTEMDRIVE” of environment) & “” & “temp”)}
Completado
move {((value of variable “SYSTEMDRIVE” of environment) & “” & “temp”)} {((value of variable “SYSTEMDRIVE” of environment) & “” & “temp_trendmicrocpm”)}
Completado
endif
Completado
continue if { not exist file ((value of variable “SYSTEMDRIVE” of environment) & “” & “temp”)}
Completado
// run installer. To avoid a Windows API bug, the -i option should always be the last one
Completado
if {((parameter “install_path” of action)) as string = “”}
Completado
// default path
Completado
if {version of client < “8.0”}
Completado
waithidden “{download path “TMCPMInstaller.exe”}” -l “en” -i “{name of drive of system folder & “” & following text of last “” of value of variable “ProgramFiles” of environment & “\Trend Micro”}”
Completado
else
Fail
