Quick way for an onsite tech to tell a workstations status?
(imported topic written by ktm_200091)
Hi All,
I’ve had a few complaints from my desktop team that Big Fix takes a long time to patch and they can’t tell what is going on. It seems that most times when they are complaining the PC is waiting for a reboot and they either snoozed the restart pop-up or in smaller cases the restart pop-up did not pop-up.
Is there a way to easily see what the status of the client is other than reading the log file:
C:\Program Files\BigFix Enterprise\BES Client__BESData__Global\Logs
Ideally info contained would have:
Patches Needed
reboot state
Admin login needed
Hey ktm,
I guess I am not clear on the problem… If the user is snoozing the restart, isn’t that because you selected the “allow user to postpone” action option? Is that considered a problem?
But if your question is: “How can you see status of the system from the local computer?”, then the answer is the BigFix Client Dashboard… The idea with the client dashboard is that you can have the little BigFix icon in the system tray and you can customize a view for the user (or for the technician with a secret key stroke) that will display whatever info you want.
The only trick is that you will need to customize your dashboard and deploy to your agents…
Here is some more info (with examples):
http://forum.bigfix.com/viewtopic.php?pid=5261#p5261
Here is some more info on where the files live for the client ui dashboard:
http://support.bigfix.com/cgi-bin/kbdirect.pl?id=524
(imported comment written by ktm_200091)
The later is what I am looking for, thanks!!!
tried it out… Good stuff
What method does one use to customize the content?? is this just relevance lanquage put into html? so could I test the relevance with the QNA tool and then put it into the .html file?
Yes, it’s just tags inside of HTML.
Check out “Creating Client Dashboards” on page 60 of the Admin Guide.
http://support.bigfix.com/product/documents/BESAdminGuide-7.0.pdf
Need some help with the relevance in the Dashboard.html file. Is there any documentation of how to write the language??
I’d like to integrate some of the analysis I put together to monitor workstations on the dashboard so the tech only has to goto one place to view the pc status.
Here is an analysis I use to monitor Symantec:
if exists service “Symantec Antivirus” then state of service “Symantec Antivirus” else “”
Here’s what I have so far trying to copy the style of existing if then else statement
Symantec Antivirus State: <?relevance (if exists service "Symantec Antivirus" then state of service "Symantec Antivirus" else "")?>
Can the dasboard evaluate this info?
Yep… It looks right to me… So put that in the _Dashboard.html file, put it in the right place (according to the KB article) and restart the agent (you always need to restart the agent to see the updated dashboard file)… You will probably want to enable the dashboard to always show the icon with the Tasks in the BES Support site to make it easy for the users to click on them…
On a related note… I want to use Javascript in my Dashboard file, however the EvaluateRelevance function is not available resulting in an Object Expected error.
Is there any way I can manually include that function. I searched but couldn’t find a .js file that defines that function anywhere within the standard client installation, but I see it used all of the time, so I must be missing something.
Hi jfry,
Yes… I believe you can’t use EvaluateRelevance in a client dashboard (only in a console dashboard)…
Will you guys post a screenshot of your client dashboards? I am curious what you came up with…
Here’s the text with userid/computernames deleted
Computername
(Last updated: Thu, 13 Aug 2009 09:45:43 -0400)
Refresh
Computer Information
OS: WinXP 5.1.2600
RAM: 3070 MB
DNS Name: Computername
Disk Free Space: 18001 MB
Logged in users: Username
Does PC require a Restart? False
Does PC required an Administrative Login? False
Is Group Policy Applying Correctly?: True
Symantec Antivirus Service State: Running
Symantec Antivirus Virus Definition Date: 20090812
Does This PC have the Courion Client Installed?: True
Is Courion Registered Properly? (If Result is False the PC Requires a Reboot): True
Pointsec Protector Service Status: Running
Does PC require Pointsec Whole Disk?: True
Pointsec Whole Disk Service Status: Running
This PC is requires 2 fixlets
Fixlet Name Severity Release Date
Java Runtime Environment 5.0 Update 20 Available 04 Aug 2009
Java Runtime Environment 6 Update 15 Available (JRE < 6 Installed) 04 Aug 2009
Note:Not all of the items reporting in as required have been released for installation, Please ignore Fixletes for
(IE7,IE8, Java 1.50 Update 19, Java 1.6 Update 14)
Cool! Glad to see you are getting good use from this feature…
