I have questions about importing part number:
Under Part Number upload page, there is an option called “Remove all Part Number for Selected computer group”. Once it is selected to remove a specific part number, can it be undo as there is no option to undo this?
Is there a way to export the current “Imported Part numbers” via REST API call?
all custom imported part numbers are stored inside this [adm].[current_part_numbers] table only?
Thanks.
Regards,
York
