I’m preparing to install BigFix Inventory 9.x and have a concern about one of the “Limitations” listed in the documentation.
Distributed Server Architecture (DSA) is not supported
Distributed Server Architecture (DSA) allows for setting up multiple BigFix servers that can replicate data between themselves. If the main server is disabled, a backup server takes over its role ensuring continuous work. The architecture is not supported because BigFix Inventory can be connected only to one of the replicated servers at a time. When you try to add another server, a message is displayed saying that such a database is already connected.
Does this mean I can’t install the software if I use DSA or does it mean I can’t switch Inventory to the Secondary server if the Primary fails?
