QnA problem on Mac client 9.5.2
Do others see a problem with evaluating this on the latest Mac client?
Q: version of client
A: 9.5.2.56
T: 22675
Q: folders "Library" of folders of folder "/Users"
E: The expression could not be evaluated:
T: 5533
On older versions of QnA this works:
A: 9.2.5.130
T: 3794
A: /Users/aaron/Library
A: /Users/admin.melgares/Library
A: /Users/melgares/Library
T: 423206
This isn’t specific to the Library folder, it’s any query of the form:
folders "xxx" of folders of folder "xxx"
Hello
I reported this same issue here: SOLVED: Issue with folders "..." of folders on Mac OS
I noticed that it was caused by a folder in users missing the library folder and the inspector errors out. If all of the folders being checked have the queried folder then it works.
Thanks! Did you open a PMR for this?
I can’t open PMRs :frowning:
But you definitely should!
PMR has been opened for it. We’re addressing this. Thank you.
