I’m trying to create/run a python script in a fixlet and for some reason it’s throwing an error trying to set counts = {}. Does Bigfix need some sort of escape for curly brackets to get past this step? The script runs fine on it’s own so I know its not a python error its something the fixlet doesn’t seem to like.
if {(name of (operating system) as string as lowercase contains "linux")}
//Deleting the append file
delete __appendfile
//Moving to file location and removing previous run
appendfile #!/bin/sh
appendfile cd /beanstore-client/dg/util
appendfile rm batchtable.py
appendfile rm batchdata.txt
//modify appendfile to allow execution
wait /bin/sh -c "chmod 555 {(client folder of current site as string) & "/__appendfile"}"
//execute shell script as written
wait "{(client folder of current site as string) & "/__appendfile"}"
// Batchtable.py starts after the following line
createfile until _EOF
#!/usr/bin/env python
import re
import glob
import sys
if len(sys.argv) > 1:
logfiles = sys.argv[1:]
else:
logfiles = glob.glob("/beanstore/PosErrlogs/retailErrlog*")
re_batch = re.compile("^(?P<log_date>....-..-..) ..:..:..,.........: INFO : \[TillReceiver\] com\.pcmsgroup\.v21\.dfm\.tillreceiver\.TillReceiverSupportImpl: TillReceiverSupport Status:.* Processed batch = .*[^0-9](?P<batch_year>20[0-9][0-9])(?P<batch_month>[0-9][0-9])(?P<batch_day>[0-9][0-9])([0-9]{6})?[^0-9]")
counts = {}
Great that worked Jason I appreciate the help. I have come upon a new issue now that I have the full script working. I am creating the python script and using an appendfile to run it and in that appendfile I am trying to output the run to a txt:
appendfile ./batchtable.py >> batchdata.txt
The issue I have is that the file is being created but it’s empty. Is there something special I have to do to actually capture the output of the run python script or do I have to create the file in the python rather than pushing the output to a file on the linux box?
I’m not sure the context there - are you creating a second appendfile to launch the Python script? Is this second file going to be interpreted by bash, or /bin/sh, or ??
Otherwise, if this isn’t a second __appendfile, I think you should handle redirection on the wait command…
For context, this can definitely be handled to do output (or input) redirection, but often requires careful quoting so the redirection is handled at the correct level. I should be able to find a reference later, but if memory serves you should be able to do something like
So here’s the full script to show what I am trying to do. The idea is to create the python script, run it and send the output to a .txt file, delete the python script and then we have another tool to pull the text file out for analysis.
delete __appendfile
appendfile cd /beanstore-client/dg/upload
import re
import glob
import sys
else:
re_batch = re.compile("^(?P<log_date>....-..-..) ..:..:..,.........: INFO : \[TillReceiver\] com\.pcmsgroup\.v21\.dfm\.tillreceiver\.TillReceiverSupportImpl: TillReceiverSupport Status:.* Processed batch = .*[^0-9](?P<batch_year>20[0-9][0-9])(?P<batch_month>[0-9][0-9])(?P<batch_day>[0-9][0-9])([0-9]{{6}})?[^0-9]")
counts = {{}}
log_dates = set()
batch_dates = set()
for filename in logfiles:
f = open(filename)
for line in f:
matchobj = re_batch.match(line)
if matchobj:
d = matchobj.groupdict()
log_date = d["log_date"]
log_dates.add(log_date)
batch_date = "%s-%s-%s" % (d["batch_year"], d["batch_month"], d["batch_day"])
batch_dates.add(batch_date)
key = log_date,batch_date
if key in counts:
counts[key] += 1
else:
counts[key] = 1
f.close()
log_dates = sorted(log_dates)
batch_dates = sorted(batch_dates,reverse=True)
for batch_date in batch_dates:
line = batch_date
for log_date in log_dates:
if key in counts:
count = counts[key]
else:
count = "-"
line = line + "%7s" % (count,)
line += "\n"
sys.stdout.write(line)
log_dates_short = ["%s/%s" % (log_date[5:7],log_date[8:]) for log_date in log_dates]
log_dates_line = " " + " ".join(log_dates_short)
sys.stdout.write(log_dates_line + "\n")
_EOF
//Python program ends before the previous line
//Create a file with the Python program on the local filesystem
copy __createfile /beanstore-client/dg/util/batchtable.py
//Shell to Action Script Conversion Utility
delete __appendfile
appendfile mkdir /beanstore-client/dg/upload
appendfile chmod +x batchtable.py
delete __appendfile
If I run it manually it works without issue. The one caveat is that I had to add extra {}'s around the curly brackets in the script to get it to run in bigfix. Not sure if that is causing issues.
For the curly-brackets around the 6, you need to double the open-curlies so a Relevance substition is not started, but you do not need to double the close-curly brackets. You would only double the close-curly-bracket if this was inside a substitution, and you needed to use } as a literal string without ending the substitution. So it should look like
