Hi.
I have created a fixlet to perform the proxy setting in ie and chrome.
The fixlet works fine, it makes modifications in the registry of windows with the user that is logged.
The incident is when the endpoint user tries to change the proxyoverride setting to add ip or dns addresses.
It also happens when you try to disable the proxy
I would appreciate some help
Here mi fixle
Action 1
regset “[HKEY_USERS{name of key whose ((it = name of current user as lowercase OR it starts with name of current user as lowercase) of (it as string as lowercase) of value “USERNAME” of key “Volatile Environment” of it) of key “HKEY_USERS” of registry}\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings]” “ProxyServer”=“6xx.xx.xx.xx:8080”
Action 2 Proxy-Backup
regset “[HKEY_USERS{name of key whose ((it = name of current user as lowercase OR it starts with name of current user as lowercase) of (it as string as lowercase) of value “USERNAME” of key “Volatile Environment” of it) of key “HKEY_USERS” of registry}\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings]” “ProxyServer”=“xx.xx.xx.xx:8080”
Action 3 ProxyOverride
regset “[HKEY_USERS{name of key whose ((it = name of current user as lowercase OR it starts with name of current user as lowercase) of (it as string as lowercase) of value “USERNAME” of key “Volatile Environment” of it) of key “HKEY_USERS” of registry}\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings]” “ProxyOverride”=“xx.xx.xx.xx;.somesite;;”
