I am trying to install office and a lot of our machines have less than 1 GB free space. Normally I bfarchive.exe and package the grouping of files into 1 .tmp file. But in this case its proving troublesome since the extract balloons so much so that it fails in my test environment.
So I would like to download it from a network share if at all possible? Can this be done i.e
yes, you can have the bigfix client copy the install off a fileshare, but since the BESClient.exe runs as the local system account, it won’t be able to authenticate to the file share. To work around this issue, you’ll need to create a null file share: http://support.bigfix.com/bes/misc/null_session_share.html
then you can run your “waithidden \fileshare\office2010\setup.exe”. You will need to look into how to make the install silent if you haven’t already (http://forum.bigfix.com/viewtopic.php?pid=36318)
