It’s running them apparently but it’s taking 4-5 hours before it actually initiates anything after I do the push from the console. Nothing shows up the log except what I posted above. Any idea why this server is taking this long? Everything else seems to be fine on it.
It doesn’t look like the system is getting the UDP ping from the relay or BES server when you take the action. You should be able to see that recorded in the log… in so many words. If the UDP ping is missed the client won’t notice that it has something to do until it gathers which can easily be several hours later depending on the values you are using for your clients.
Check to see if you have firewall or something else that may be blocking that notification to the systems. The default port is UDP/52311.
