Problem with Power Options Information Analysis
(imported topic written by murtasma91)
I have the the following Analysis activated (activated this months ago) Power Options Information - Windows 2000/XP/2003/Vista/7 and Mac OS 10.4/10.5.
When I open the Analysis and select the results tab I can see the power settings for all our endpoints just fine however when I use the drop down at the upper left and select View as summary no data is getting returned. Do I have to do something else besides activate this anaysis to get this report? It looks like all the data is there when I have View as List selected.
Have you tried clearing the console cache? I can indeed see data when using the Summary view, so you should see something.
(imported comment written by murtasma91)
Just tried clearing the cache and restarting the console but I got the same results. Does viewing this as a summary require flash or some other type of plugin to display properly? I wasen’t asked to install anything when opening the report.
