I’m trying to patch my RHEL 5 server for the samba RHSA-2015:0249 patch. The patch doesn’t have actionscript and it says that I need to run the minimum package list dashboard to build my own custom patch… no problem. I go to the dashboard and it says that I need to activate the anaylses for it. I activate analyses 2 and 4 but analysis 4 never reports back for my RHEL 5.11 server. I dug into the Bootable Kernel Status - Red Hat Enterprise Linux analysis and found the last relevance as my problem.
Loading up the qna on that box reveals the following…
[root@s0u1hat bin]# ./qna
Default masthead location, using /etc/opt/BESClient/actionsite.afxm
Q: exist packages whose ((name of it = “kernel” OR name of it = “kernel-debug” OR name of it = “kernel-hugemem” OR name of it = “kernel-largesmp” OR name of it = “kernel-PAE” OR name of it = “kernel-smp” OR name of it = “kernel-xen” OR name of it = “kernel-xenU”) AND (rpm package version record (parenthesized part 1 of first match (case insensitive regex “([0-9.-]+[0-9]).el[0-9]?”) of (version of it as string))) = (rpm package version record (parenthesized part 1 of first match (case insensitive regex “([0-9.-]+[0-9]).el[0-9]?”) of (release of operating system as string)))) of rpm
E: RPM lib load error (libbfrpm.so: cannot open shared object file: No such file or directory libbfrpm.so: cannot open shared object file: No such file or directory)
T: 82665
Help/suggestions?
