Problem with excel conector
(imported topic written by ygarti91)
hello everyone
i am not sure that this is the right place
but i don’t know where is the right place so i decided to post it here
i install the excel connector installation and the installation finish successfully
but when i run excel i get this error
and when i press on the details i get
Detailed technical information follows:
(Inner Exception)
Date and Time: 17/12/2009 19:35:31
Machine Name: YANIV-PC
IP Address: fe80::b570:365f:b95f:4603%12
Current User: FNX-DOMAIN\yaniv
Application Domain: C:\Program Files\BigFix Excel Connector\
Assembly Codebase: file:///C:/Program Files/BigFix Excel Connector/AddinExpress.MSO.2005.DLL
Assembly Full Name: AddinExpress.MSO.2005, Version=4.4.1913.2005, Culture=neutral, PublicKeyToken=4416dd98f0861965
Assembly Version: 4.4.1913.2005
Assembly Build Date: 28/03/2005 01:06:50
Exception Source: Interop.Excel
Exception Type: System.Runtime.InteropServices.COMException
Exception Message: Old format or invalid type library. (Exception from HRESULT: 0x80028018 (TYPE_E_INVDATAREAD))
Exception Target Site: get_Version
  • Stack Trace ----
Excel._Application.get_Version()
AddinExpress.MSO.2005.DLL: N 00000 (0x0) JIT
BigFixExcelConnector.FormWizard…ctor()
AddinExpress.MSO.2005.DLL: N 0279 (0x117) IL
BigFixExcelConnector.AddinModule.AddinModule_AddinInitialize(sender As Object, e As EventArgs)
AddinExpress.MSO.2005.DLL: N 0001 (0x1) IL
AddinExpress.MSO.ADXAddinModule.Extensibility.IDTExtensibility2.OnStartupComplete(custom As Array&)
AddinExpress.MSO.2005.DLL: N 0654 (0x28E) IL
(Outer Exception)
Exception Source:
Exception Type: AddinExpress.MSO.ADXExternalException
Exception Message: An error has occured in the code of the add-in.
Exception Target Site: Object reference not set to an instance of an object.
dose any one know how to fix it ?
(imported comment written by ygarti91)
someone help!!!
ygarti,
Sorry to hear that you are having this problem.
  • What version of Excel are you using, and what is the language.
  • For the user who installed the BigFix Excel Connector, there is a log file located in the following directories:
C:\Users\user_name\Documents\Add-in Express\adxloader.log (Vista, Windows 7 systems)
C:\Documents and Settings\leewei\My Documents\Add-in Express\adxloader.log (XP systems)
Can you please attach the installation log file.
Lee Wei
i have windows vista business 32 bit
office 2007 sp2 English
ygarti,
This might be the bug in Excel if you run an English version of Excel and your locale setting is non-English.
http://support.microsoft.com/kb/320369
Might this be your scenario?
If it is, the fix is to install the Multilingual User Interface Pack for Office 2007.
Lee Wei
