Problem with command "regedit /s" within a .CMD script
(imported topic written by jmlafreniere91)
Hello, I’m trying to deploy a script to some workstations and I can’t seem to make it work so maybe you can help.
I’m using the Windows Software Distribution Wizard to upload the content of a directory to the Bigfix server that contains the following:
branding.cmd
adjustments.reg
The “branding.cmd” does the following:
if exist “%programfiles%\logo” goto logo
mkdir “%programfiles%\logo”
:logo
copy /y \\logo.bmp “%programfiles%\logo\logo.bmp”
regedit /s \\adjustments.reg
The registry key looks like the following (some lines were removed to shorten a bit):
HKEY_CURRENT_USER\Control Panel\Desktop
“ActiveWndTrkTimeout”=dword:00000000
“AutoEndTasks”=“0”
“CaretWidth”=dword:00000001
“CoolSwitch”=“1”
“CoolSwitchColumns”=“7”
“CoolSwitchRows”=“3”
“CursorBlinkRate”=“530”
“DragFullWindows”=“1”
“DragHeight”=“4”
“DragWidth”=“4”
“FontSmoothing”=“2”
“FontSmoothingOrientation”=dword:000000
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Desktop\General
“TileWallpaper”=“0”
“WallpaperStyle”=“2”
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
“ListviewShadow”=dword:00000000
HKEY_CURRENT_USER\Control Panel\Colors
“Background”=“255 211 82”
I’m using a .CMD script to apply the reg keys because there are so many that I don’t want to add them one by one in a fixlet and until now, and I cannot make that work, nor the Windows Registry Wizard.
I’ve added some “pauses” to see what’s going on and, when removing the “/s” to the regedit command, I see the window that ask if I want to merge the registry, and even though it seems to work, IT WON’T DO ADD THE CHANGES in the registry.
Here’s what my action look like:
download http://bigfix.cogeco.com:52311/Uploads/3abbfb6b656306d83bb658585c3360e52597f6bd/Branding.tmp
continue if {(size of it = 701741 AND sha1 of it = “3abbfb6b656306d83bb658585c3360e52597f6bd”) of file “Branding.tmp” of folder “__Download”}
extract Branding.tmp
wait __Download\brandingfr.cmd
What could be wrong ? I’m starting to think that I’m a complete dumba$$ but up to now creating Bigfix scripts is not that straightforward.
UPDATE:
I’ve found that the change is applied to HKEY_USERS.DEFAULT instead of HKEY_CURRENT_USER. Maybe this information can help me troubleshooting my issue.
SECOND UPDATE:
I’ve also found out that there’s a checkbox called “Run as current user” when using the Windows Registry Wizard, but it says the user needs to have admin rights which is a non sense to me. I can’t find the same option using Windows Software Distribution Wizard.
Thanks,
Jim
(imported comment written by jmlafreniere91)
I made it work, but in a “unfashioned” way.
I’m using multiple “regset” to change the wanted registry keys and I’m wondering if I can use an “append” command or if I can change multiple values under a specific key without putting the whole string in the front. Here’s my example:
regset “” “ActiveWndTrkTimeout”=dword:00000000
regset “” “AutoEndTasks”=“0”
regset “” “CaretWidth”=dword:00000001
I tried this and it doesn’t work:
regset “” “ActiveWndTrkTimeout”=dword:00000000 “AutoEndTasks”=“0” “CaretWidth”=dword:00000001
OR
regset “”
“AutoEndTasks”=“0”
I don’t want to use “Windows Registry Wizard”. This is the only way I could make registry changes to the current logged on user.
Regards,
Jim
