I have a problem on iltm web report about Hardware Inventory report not sync with the BigFix Console. What should I do ?
Thank you sir.
I would start by looking at the health of your Data Imports and see if there are any errors in the logs.
I would also open a PMR on this as you will get a more immediate response/assistance on this issue.
Read about how to register and file a PMR / SR here: http://www-01.ibm.com/software/support/servicerequest/quick_start.html62
Direct link to the PMR / SR tool: https://www-947.ibm.com/support/servicerequest/newServiceRequest.action
@maitree123, have you had successful ILMT imports? If so, when did the imports start failing?
IILMT import is successful but data in ILMT and real hardware are difference.
