I have tried changing the quotation marks for %22 (I have read in another thread), but it still continues doing the same, it doesn’t fail, it gives a not reported status, but it does nothing. I’m doing through manage software distribution dashboard but not guessing how to do it.
%22 is really only needed for relevance. In the actionscript, it should be able to handle quotation marks just fine (I’ve done it before). Might be helpful if you can tell us what is the error specifically and provide us with at least a snippet of what it looks like in the actionscript.
Without knowing anything about your executable, are you sure it’s “/S /V” (upper case) and not “/s /v” (lower case). Another thing to test is if your executable can only run in the local user context rather than the system user context. Additionally, did you test it out manually yourself in the command prompt?
