Hi
Strange one this. I’m trying to evaluate the local environment variable called “ProgramFiles” on an x64 machine.
The relevance is easy:
value of variable “ProgramFiles” of environment
However, it returns “C:\Program Files (x86)”. The actual environment variable returns “C:\Program Files” when queried from the command line.
What’s the way to get the ‘true’ environment variable value?
Adam
(imported comment written by arnaud91)
Hi Adam,
Try this:
Q: value of variable “ProgramW6432” of environment
A: C:\Program Files
Some explanations here: http://msdn.microsoft.com/en-us/library/aa384274(VS.85).aspx
Basically, if you run cmd.exe on a 64bit machine, it runs as a 64bit process, so %programfiles% is set to “C:\Program Files”
But the BigFix Client (or the Relevance Debugger if you use it) runs as 32bit process, so %programfiles% is set to “C:\Program Files (x86)”
Arnaud
