(imported topic written by mholder91)
My primary relay ran out of disk space last night and now I can’t get any of the clients to respond. I’ve corrected the disk space issue, rebooted both the root server and the primary relay, but since everything is routed through the primary relay, including all other relays, nothing is responding anymore. Many of the clients have up to date “last report times”, but none of them are responding to any actions. Actually, I take that back. I deployed a service pack task to a handful of machines last night and targeted them by a manual group. All of the machines in this group are now showing as having the SP installed, but the task that I deployed isn’t even registering any applicable machines. The deployment health check dashboard shows that all of my relays are several actionsite versions behind. As a matter of fact, they’re all stuck on the exact same version.
Does anyone have any suggestions?
Should I just open a support case?
What would be the repurcussions if I uninstalled and re-installed the primary relay?
Any help is appreciated. Thanks.
