I get no errors. I see the dashboard from the previous version. It looks like this dashboard didn’t get updated. I am able to upload Android or IOS applications as before, but the option to select the Divide extender domain doesn’t appear.
Uploading applications to the Divide Cloud Service is done with the Divide Policy Management Dashboard, which is specific to Enterproid Divide’s management solution. Only Android application uploading is supported. This dashboard is located in the Mobile Device Management domain -> Security Policies -> Divide Policy Dashboard.
I think you are referring to the Enterprise App Management Dashboard, which currently supports both iOS and Android application management.
