Team, i have tried to run a sample powershell script by calling powershell.exe and also using
waithidden { pathname of file ((it as string) of value “Path” of key “HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\PowerShell\1\ShellIds\Microsoft.PowerShell” of native registry) } -ExecutionPolicy Bypass -File “C:\Temp\powershell.ps1”. But both of the cases i am unable to run that sample script powershell.ps1. Please help me.
I evan copied powershell.exe on that location and put that in to temp folder. But not working but if i run manually, it is running.
Thanks willougd for your help. Tried this one also. Action has been completed successfully with exit code 0 but that script did not run. No clue what is the issue is.
It’s difficult to guess without some idea of what the Power she’ll is trying to do.
Consider the normal limitations of the BigFix client environment -it runs as LocalSystem and in 32-bit mode by default.
Include action uses wow64 redirection false to force 64-bit mode.
If the Powershell script is trying to connect to a network UNC share, that won’t work as LocalSystem.
When you test this Fixlet downloaded from bigfix.me, not using your own .ps, but using the .ps that comes with the demo, do you end up with the “config_powershell.log” output file in your “C:\Program Files (x86)\BigFix Enterprise\BES Client__BESData__Global\Logs” folder?
I am asking you test this to help isolate if the issue is with your .ps or with the BigFix agent you are running the action on.
I just tried it and the demo worked great.
At 11:17:45 -0500 - actionsite (http://BrollyTest:52311/cgi-bin/bfgather.exe/actionsite)
Relevant - Run: PowerShell Script - Windows - TEMPLATE (fixlet:228)
At 11:17:45 -0500 -
ActionLogMessage: (action:228) Action signature verified for Execution
ActionLogMessage: (action:228) starting action
Wow64 redirection disabled. action uses wow64 redirection {not x64 of operating system} (action:228)
Command succeeded delete No 'C:\Program Files (x86)\BigFix Enterprise\BES Client\__BESData\actionsite\__createfile' exists to delete, no failure reported (action:228)
Command succeeded createfile until (action:228)
Command succeeded delete No 'C:\Program Files (x86)\BigFix Enterprise\BES Client\__BESData\actionsite\powershell.ps1' exists to delete, no failure reported (action:228)
Command succeeded move __createfile powershell.ps1 (action:228)
Command started - waithidden C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy Bypass -File powershell.ps1 (action:228)
At 11:17:45 -0500 -
Encryption: optional encryption with no certificate; reports in cleartext
At 11:17:53 -0500 -
Report posted successfully
At 11:17:53 -0500 - actionsite (http://BrollyTest:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded (Exit Code=0) waithidden C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -ExecutionPolicy Bypass -File powershell.ps1 (action:228)
At 11:17:53 -0500 -
ActionLogMessage: (action:228) ending action
Not Relevant - Run: PowerShell Script - Windows - TEMPLATE (fixlet:228)
Thanks brolly33 for your help. I tried this one also. Problem is, the code contains 150 lines, and sometimes i need to bypass the { by {{ when function comes. So i am trying to execute the .ps1 file from the location itself by calling powershell.exe.
@SubhrajitPyne Thanks for giving us the results from that test. So you can run a simple .ps script, but your specific script is not executing well. You might need to share the contents of the .ps with us in order to try to figure out what in your script is causing either “Failure to Launch” or “Failure to Complete”.
Thank you so much brolly33. The issue was in my script. It calls namap which causes a dos window open. So, the script terminates there and it never goes further…
