, the following error message was displayed in the
Aggregate Statistics
section:
“Warning: This section cannot be filtered.”
Is it possible to filter
by changing settings?
■Q2
It requires to click
Store Historical Data
button on
Dashboards
Power Tracking Information
to update the following 2 web reports, but is it possible to set to update those reports automatically on the scheduled time? If it does not require an operator’s action that would be better.
A1: You can not filter the aggregate data because at the time the statistics are calculated on historical properties we throw away the data about which computer submitted the data. This is to keep the data 2 dimensional instead of 3 (time x value vs. time x value x computer). If we kept all the data your database would bloom rapidly and you’d risk losing the nice realtime nature of BigFix. However, you can get around this limitation to some extent by creating new non-master operators and as each new operator use the dashboard to target the set of computers you’d like to consider in your data set. In this way you get a new property tracking the aggregate data for each operator and each property has a different set of computers reporting to it.
A2: We have a script you can set as a scheduled task on the server that will periodically save the data for all operators. Contact naveed_makhani@bigfix.com to get a copy and the implementation details.
