I have an issue with the wizard when i tried to schedule a wake on lan on 1 subnet.
The expiration of the action is set to 1hr
Temporal distribution is set to 5min interval
Wakeup point:
use computers that have not reported is set to within 15 min
The computer in the subnets starts to boot up but only several machines are successfully boot into windows and the rest seems to be stucked in the bios bootup screen.
Is there a specific duration required for it to be fully booted up into windows?
How long it usually takes if the machine was powered off?
If the computer have started at all, it means that they received the WoL packet… I am not sure why they are stuck on the WoL screen, but it sounds like a hardware issue… you might try to reproduce outside of BigFix…
That really sounds like an issue with the BIOS… either a BIOS setting that is misconfigured or a bug in the BIOS firmware. Does the BIOS boot screen say anything in particular? Where does it stop at?
