system
July 15, 2014, 5:35pm
1
(imported topic written by Integrator)
Via SOAP i can only get information from the webreports but REST goes further and there are also several posts possible. But does anyone know if it’s possible to run or start fixlets / tasks using REST?
Here is de REST API information:
https://www.ibm.com/developerworks/community/wikis/home?lang=en#!/wiki/Tivoli%20Endpoint%20Manager/page/REST%20API
(imported comment written by gearoid)
Yes you certainly can.
It’s as described here:
https://www.ibm.com/developerworks/community/wikis/home?lang=en#!/wiki/Tivoli%20Endpoint%20Manager/page/RESTAPI%20Action
Post to the /api/actions and put the XML into the body of the post.
This XML, for example, will create a new action for fixlet ID 168 (set client CPU) in the BES Support site and target the computer with ID 9144053.
<?xml version="1.0" encoding="UTF-8"?>
<SourceFixlet>
<Sitename>BES Support</Sitename>
<FixletID>168</FixletID>
<Action>Action3</Action>
</SourceFixlet>
<Target>
<ComputerID>9144053</ComputerID>
</Target>
system
July 16, 2014, 9:43am
3
(imported comment written by Integrator)
Thanks gearoid, i will try it.
