When I originally installed SCM on a server, it installed itself under the BES Client folder on the C: drive, but I need to move the installation to another location.
The SQL is “local”. Is there any documented procedure on how to move the instance from the C: drive to another location without losing all of our data?
Can I simply uninstall SCM and reinstall it on a different drive? The data should all be in the SQL database, right?
