- stop wincollect service
- Run the following script:
wincollect-7.3.0-41.x64.exe /s /v"/qn INSTALLDIR=“C:\Program Files\IBM\WinCollect” HEARTBEAT_INTERVAL=6000 LOG_SOURCE_AUTO_CREATION_ENABLED=True LOG_SOURCE_AUTO_CREATION_PARAMETERS="“Component1.AgentDevice=DeviceWindowsLog&Component1.Action=create&Component1.LogSourceName=%COMPUTERNAME%&Component1.LogSourceIdentifier=%COMPUTERNAME%&Component1.Dest.Name=QRadar&Component1.Dest.Hostname=10.0.70.108&Component1.Dest.Port=514&Component1.Dest.Protocol=TCP&Component1.Log.Security=true&Component1.Log.System=true&Component1.Log.Application=false&Component1.Log.DNS+Server=false&Component1.Log.File+Replication+Service=false&Component1.Log.Directory+Service=false&Component1.RemoteMachinePollInterval=3000&Component1.EventRateTuningProfile=High+Event+Rate+Server&Component1.MinLogsToProcessPerPass=1250&Component1.MaxLogsToProcessPerPass=1875"”" - Start the wincollect service
Possibly the easiest option is do this as PowerShell script where you can then add the safety checks to validate the services stop|start successfully then use the fixlet action to create the script. The PowerShell code you can paste that directly into the ActionScript, using the PowerShell option.
You would need to make sure you download the wincollect executable into software distribution then use it in a prefetch to download it to the machine but then you could just do:
//prefetch section or the download command to download it
//---- stop service
waithidden cmd.exe /c net stop “Wincollect”
//----install/upgrade Wincollect
waithidden __Download/wincollect-7.3.0-41.x64.exe /s /v"/qn INSTALLDIR=“C:\Program Files\IBM\WinCollect” HEARTBEAT_INTERVAL=6000 LOG_SOURCE_AUTO_CREATION_ENABLED=True LOG_SOURCE_AUTO_CREATION_PARAMETERS="“Component1.AgentDevice=DeviceWindowsLog&Component1.Action=create&Component1.LogSourceName=%COMPUTERNAME%&Component1.LogSourceIdentifier=%COMPUTERNAME%&Component1.Dest.Name=QRadar&Component1.Dest.Hostname=10.0.70.108&Component1.Dest.Port=514&Component1.Dest.Protocol=TCP&Component1.Log.Security=true&Component1.Log.System=true&Component1.Log.Application=false&Component1.Log.DNS+Server=false&Component1.Log.File+Replication+Service=false&Component1.Log.Directory+Service=false&Component1.RemoteMachinePollInterval=3000&Component1.EventRateTuningProfile=High+Event+Rate+Server&Component1.MinLogsToProcessPerPass=1250&Component1.MaxLogsToProcessPerPass=1875"”"
//----start service
waithidden cmd.exe /c net start “Wincollect”
