Essentially, I am looking to use the officec2rclient.exe that the suite uses to update rather than actually load a package…completely new to Endpoint Manager and have no action/relevance language skills yet.
Any help creating a fixlet template to run the officec2rclient.exe would be greatly appreciated.
I suggest you check out the Endpoint Manager Action Guide, specifically the prefetch command, which downloads a file, and the wait command, which runs an executable.
After you’ve read through that, this action script will make sense:
