Patch Management
(imported topic written by PBigfixadmin91)
I cannot see latest patches (Since 13th April 2010) for XP desktops in Bigfix , where if i try to update my machine from Windows Update option i see latest update till June 2010…plz help.
It sounds like your server may not be able to gather the newest content. This might be caused if you are using a proxy and your proxy user’s windows password changed for some reason.
You can contact BigFix support and they can assist you in troubleshooting this issue.
(imported comment written by PBigfixadmin91)
But, i can see other Fixlets then Windows are getting updated appearing in “All Relevant Fixlets”…?
Server is accessing internet throught LAN connections no proxy defined.
