Patch management for subsystems
I’m new to IEM. Can somebody help me with my below query ?
Can we do patch management for subsystems like,
Oracle
SQL
WAS
DB2
IIS
V-center
IBM HTTP server
Symatic Vertias Netbackup and Exec
IIB
Where do I get link to find what all softwares supported for patch management by IEM 9.x ?
Appreciate your quick response.
Thanks in Advance
IEM / BigFix can be used to patch basically anything.
If it can be done on the command line, then it can be done through IEM / BigFix, but even in cases where the command line might not be an option, there can be workarounds. The command line also includes anything that can be initiated through the command line, including PowerShell, VBScript, AutoIT, etc…
However, doing all of this requires that either IBM provide patching content for you, OR you get the content from somewhere like BigFix.Me, OR you make it yourself.
My guess is for many of those items you are asking about, you would have to make the patching content yourself, though there is definitely some related content already on BigFix.Me
