Patch is not applicable but showing missing in webreport
(imported topic written by wasseemkhaan91)
Patch MS09-004 is showing missing in some of the servers while generating the webreport but this patch is not showing applicable in those servers if I see in console.
Can anyone pls help me in this
Hey wasseemkhaan,
You might want to check with support…
Note that there usually are multiple Fixlets for a single bulletin so make sure you are looking at the same Fixlet for both the console and the web reports.
