Patch deployment on machines connected via wireless network
(imported topic written by maipeng91)
Found problem deploying patches on machines that are connected via wireless network, the status of those machines reported as .
Any clue for me please, thank you in advance.
Welcome to the forum.
Most likely, this is firewall or connectivity issue. Here are some things you should look at:
Do these machines have a software firewall enabled?
Is there a hardware firewall between the relay and the client?
Are these machines using NAT (private IP addresses)? If so, is there a relay inside the NAT’d LAN, and if so, are these machines pointing to that relay?
Here’s the knowledgebase article you should check out for more troubleshooting tips regarding client connectivity and reporting: http://support.bigfix.com/cgi-bin/kbdirect.pl?id=173
