Parameterized Fixlet not showing parameters [SOLVED]
I have a parameterized fixlet that is not showing the parameters for certain users. I checked IE settings for users and scripting is enabled. Does anyone know of another setting that might cause this issue??
thanks in advance!
Could share the log lines related to this action?
Could you share the fixlet/task that you use to create this action with parameters?
When you say “now showing” the parameters for certain users, how do you mean?
-jgo
Might help if I spell the issue correctly! The parameters are NOT showing for them in the console. I’m assuming it has to do with an IE setting of some kind, but I checked their scripting setting and it is set to enabled. when the pull up the fixlets they see no parameters, but i pull it up on my system in my console and I see them without issue.
Parameterized fixlet depend on the ‘Parameterized Fixlet Library’ is part of ‘BES Support’ site.
Other than this library fixlet must be globally visible, need operators managing parametrized fixlets have access to the ‘BES Support’ site …
If this does not help, probably it is better proceed opening a PMR …
Thank you @gpoliafico, I looked and the fixlet was hidden, it worked for my MO account though. I made it visible and now operators can see the parameters!
Cheers!
