Hello,
I am trying to package a deployment package for manage engine central agent but I get error code 1605 anyone can help me figure out what’s wrong in following code?
I’m following this guide I have built version above 10.1
https://www.manageengine.com/products/desktop-central/silent-agent-installation.html
Failed exit code 1605
wait "{pathname of system folder & "\msiexec.exe"}" /i "{(pathname of client folder of current site) & "\__Download\"UEMSAgent.msi"}" /qn TRANSFORMS="UEMSAgent.mst" ENABLESILENT=yes REBOOT=ReallySuppress INSTALLSOURCE=Manual SERVER_ROOT_CRT="%cd%\DMRootCA-Server.crt" DS_ROOT_CRT="%cd%\DMRootCA.crt" /lv "Agentinstalllog.txt
You should probably build the statement in a batch file so you can see what installation string results. At minimum there’s a doublequote issue on "\__Download\"UEMSAgent.msi"
- the doublequote before “UEMSAgent” terminates the string early.
The installer may also require disabling 32-bit redirection.
The variables for SERVER_ROOT_CRT
and DS_ROOT_DIR
may not resolve correctly because they are based on resolving %cd%
- so these files are expected to be in the current working directory, but might actually be under __Download
(or somewhere else, I don’t know where your files are)
Thanks for your help by removing the doublequote solved the problem.
Great to hear it was a simple fix!
