Hello,
I am experiencing a very strange errors on a fixlet that I am creating. The fixlet downloads and extracts a package and should move & install it. I used the Software Distribution Wizard to upload it and generate the download & extract code for me, and just added a few lines of code to copy it to a different location and run the installation:
download http:
//168.74.26.100:52311/Uploads/1a85e3e2d492075dc540f49e137442828e16dd7e/CPS45_EN_W2K3.tmp
continue
if
{(size of it = 290988685 AND sha1 of it =
"1a85e3e2d492075dc540f49e137442828e16dd7e") of file
"CPS45_EN_W2K3.tmp" of folder
"__Download"
} waithidden
"{pathname of system folder & "\cmd.exe
"}" /C
if not exist
"{(value of variable "windir
" of environment) & "\Temp\CPS45_EN_W2K3
"}" md
"}" extract CPS45_EN_W2K3.tmp waithidden
"}" /C xcopy /s
"{(pathname of client folder of current site) & "\__Download
"}" waithidden
"}" /C cd
"}" & CitrixBigFix32.bat
When the fixlet is ran it produces the following error:
At 15:10:49 -0400 - ActionLogMessage: (action 210319 ) starting action At 15:10:53 -0400 - CustomSite_MGTI-2dESM (http:
//168.74.26.100:52311/cgi-bin/bfgather.exe/CustomSite_MGTI-2dESM) Command succeeded (Using download manager collected file) download http:
//168.74.26.100:52311/Uploads/377331eb759515c71ce14ecaa4bac26e323a212a/CPS45_EN_W2K3.tmp (fixlet 210319) At 15:12:31 -0400 - GatherHashMV command received. Already have
this version of site. At 15:13:23 -0400 - CustomSite_MGTI-2dESM (http:
//168.74.26.100:52311/cgi-bin/bfgather.exe/CustomSite_MGTI-2dESM) Command succeeded (evaluated
true)
continue
if
{(size of it = 290987243 AND sha1 of it =
"377331eb759515c71ce14ecaa4bac26e323a212a") of file
"__Download"
} (fixlet 210319) At 15:14:00 -0400 - CustomSite_MGTI-2dESM (http:
//168.74.26.100:52311/cgi-bin/bfgather.exe/CustomSite_MGTI-2dESM) Command failed (Unable to extract archive file.) extract CPS45_EN_W2K3.tmp (fixlet 210319) At 15:14:14 -0400 - CustomSite_MGTI-2dESM (http:
//168.74.26.100:52311/cgi-bin/bfgather.exe/CustomSite_MGTI-2dESM) Relevant - test (fixlet:210318) At 15:14:14 -0400 - ActionLogMessage: (action 210319 ) ending action At 15:14:14 -0400 - actionsite (http:
//168.74.26.100:52311/cgi-bin/bfgather.exe/actionsite) Not Relevant - test (fixlet:210319)
The weird part of it is that most of the files were successfully extracted in the site’s __Download folder. I did some basic comparison between the files of the original package and the files that made it across and it seems that the problem starts at a specific folder depth, so I am wondering if there’s some kind of path length limitation? (everything above the following path is present but a bunch of files underneath are missing “C:\Program Files\BigFix Enterprise\BES Client__BESData\CustomSite_MGTI-2dWindows__Download\Support\SqlExpress_2005_SP1\SqlExpress\setup”)
Thank you.
Angel
