system
June 19, 2014, 2:50pm
1
(imported topic written by Darknight)
Can someone please let me know the rlevance required to retrive below oslevel output via relevance:
$ oslevel
7.1.0.0
Please note that i am looking for relevance to extract the oslevel not the technology relevance.
Thanks in advance.
system
June 19, 2014, 7:33pm
2
(imported comment written by xdaxdb)
I’m not an expert at this by any means but I was looking into this exact thing not long ago. There does not seem to be an inspector that can detect this automatically.
I think you would have to write an action that would execute the command “oslevel -r” and then report that information back… somehow. If you figure it out please post back because I’m curious myself. I’m still working on rolling out IEM, totally new to this, but we have a lot of AIX where I am.
system
June 20, 2014, 1:26pm
3
(imported comment written by Darknight)
ok xdaxdb…Even i have not found any inspector to find out teh relevance to get the oslevel of AIX maxchine but have not found any…
Fro the command oslevel -r it seems you are tyrying to get the technolgy level of AIX serer , if this is the case then you can use the below relevance to get the result:
if
(version
of
client
“8.2”
then
if
exists
((line
1
of
file ((pathname
of
(parent folder
of
client folder
of
current site))
“/__OSLevel/oslevel.txt”
as
string)
whose
exists
match (regex
“^[0-9]}-[0-9]{2{4}$”
of
it
then
parenthesized part
1
of
match (regex
“^[0-9]{4}-([0-9]{2})$”
of
(line
1
of
file ((pathname
of
(parent folder
of
client folder
of
current site))
as
string)
else
“N/A”
else
(parenthesized part
1
of
match (regex
of
(current technology level
of
operating system
as
string))
system
June 24, 2014, 7:49pm
4
where does the file oslevel.txt come from?
system
June 24, 2014, 11:01pm
5
Why not just use
current service pack of operating system
What is the point of all that other stuff? ( I just learned about that inspector from
https://support.bigfix.com/inspectors/System Objects_AIX.html
system
June 25, 2014, 12:27pm
6
i have tried this before but this relevance will return :
7100-02-02-1316
which is not the requirement. I am trying to get teh below output via relevance :
7.1.0.0
which is basically output of AIX command : oslevel.
Can someone help in retriving this value via relevance.?
system
June 25, 2014, 6:57pm
7
release of operating system
will output:
7.1
6.1
5.3
etc
jgstew
July 27, 2014, 2:52am
8
what does (version of operating system) give you? … I don’t know AIX.
(imported comment written by gearoid)
Check the operating system inspectors
http://support.bigfix.com/inspectors/System%20Objects_Any.html#operating%20system
I think ones you want for AIX Platform are current technology level, and current service pack ?
More on what these all mean here
https://www.ibm.com/developerworks/community/blogs/AIXDownUnder/entry/understanding_aix_levels6?lang=en
http://www-01.ibm.com/support/knowledgecenter/ssw_aix_61/com.ibm.aix.cmds4/oslevel.htm?lang=en
Running oslevel without flags is giving you a formatted version of the base level, which is the first 4 digits of the oslevel -r.
current technology level of operating system is same as oslevel -r.
current service pack of operating system is same as oslevel -s
On my AIX:
oslevel -r
7100-00
oslevel -s
7100-00-03-1115
In qna
Q: current technology level of operating system
A: 7100-00
Q: current service pack of operating system
A: 7100-00-03-1115
