Hi all
I have activated the “get oracle feature” task. It’s possible to have the results in web reports console?
Results for what? Get Oracle Feature task just creates some swidtag files which BFI uses to detect Oracle features installed.
There is an analysis in the IBM Bigfix Inventory v9 external site called “Oracle Feature Health check” which shows debugging information for the above task. Once activated, you can see this on WR too.
But you can see the actual information only on BFI’s Oracle databases report.
Tnx Rohit, but the question is if is possible to see the Oracle databases report in web reports console. This because i would like to schedule them, send by mail, and archive. And i think that this is possible only in web reports and not in big fix inventory web portal.
Actually you can do the same using BFI. If you go to Reports -> Oracle Databases and then click on Schedule export (alongside the option to save as csv). You can schedule a report the same way as you schedule reports in WR.
