HI Team, Requiring your support to resolve below mentioned issue. I’m not able to generate Broker code although i have edited trc_broker.properties file and when i checked the logs found below error.
Hello Rishabh,
Is the key.p12 in PKCS12 format ? Does it contains a valid certificate ? If the answer is yes check the password specified in the DefaultTLSCertificatePassphrase property. If the password contains “:” you might need to escape it like this “\:”.
Above mentioned issue has been resolved by creating new certificates and changing the broker ports.
