Office Project Installation
Hi.
Created one package for Office Project but this is not executed might be there is some wrong silent command , please assist.
Did you try running your commands in the Fixlet Debugger? https://www.ibm.com/developerworks/community/wikis/home?lang=en#!/wiki/Tivoli+Endpoint+Manager/page/Fixlet+Debugger+(QnA)+Tool
Using the action tab, you can test both relevance and action script; for the latter, you can even step through your script line by line to get feedback on what the client is doing.
Yes I tryed with fixlet debugger and got the message completed but the package not installed
In that case, you’ll probably want to a) run the fixlet debugger as system, and b) ensure the setup runs to completion using your parameters.
Think you need the full command: setup.exe /configure [xml file]
