I’ve been having similar issues and haven’t been able to figure out is causing the Microsoft officec2rclient.exe to silently fail. The Office update logs that end up in %temp% called [machinename-YYYYMMDD-time.log] don’t provide any insight.
I see the exactly same failures at the pause while command in the BigFix action.
My users get these errors when the problem occurs:
“Outlook.exe” - Bad Image
"The application was unable to start correctly (0xc0000142). Click OK to close the application"
Office repair isn’t necessary in the cases I’ve seen. Having the user reboot will typically get the Office applications launching again. So that leads me to believe some other process is stepping on the Office update, maybe a security agent.
I just wish I could reproduce the failure consistently, because I could then do some Process Exploring.
My baselines don’t hang, eventually the Office update action will update to Failed status, but then will continue through the other components of the baseline
