I included the latest office 2019 click to run fixlet in my baseline for win10 systems. I selected action 3 so that it will force close any running office apps. What i’m seeing is that the fixlet stays in a ‘running’ state for the entire duration of the maintenance window and never makes it to the reboot fixlet at the end of the baseline and the office update is not applied. The besclient log says it started and completed successfully. I’m wondering if others have experienced something similar and if anyone has any suggestions. Thanks!
Command started - waithidden “C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe” /update user updatepromptuser=False forceappshutdown=True displaylevel=False updatetoversion=16.0.10376.20033
Command succeeded (Exit Code=0) waithidden “C:\Program Files\Common Files\Microsoft Shared\ClickToRun\OfficeC2RClient.exe” /update user updatepromptuser=False forceappshutdown=True displaylevel=False
