October 2021 - Ideas Reference
Below, please find the Ideas created in the Ideas Portal for the month of September 2021 for your reference. You can view their details, as well as vote or provide comments to those that interest you and your organization.
We will work to provide similar references here on the BigFix Forum in this Ideas category on a monthly basis for awareness and to foster additional collaboration.
Don’t have an account? It’s easy to sign up @ https://bigfix-ideas.hcltechsw.com/portal_users/new.
Thank you!
URL Idea name Workspace name
https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-99 Improve CIS Checklists Compliance
https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-234 Add Signature for PostgreSQL all version on Unix and AIX Inventory
https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-233 Support Nutanix Prism Central VM Manager Inventory
https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-132 Patching support external site for SLE15 on POWER machines. Lifecycle
https://bigfix-ideas.hcltechsw.com/ideas/IDEACNCTNS-I-2111 Add support for running BigFix server and relays on Oracle Linux Lifecycle
https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-131 log-in limitation for webui login ( from different browsers or different machines ) Lifecycle
https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-130 WebUI Functionality Individual Component Status and error details for Baseline actions Lifecycle
https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-129 Relay Drive Space Protection from "No Hash” Deployment Option Lifecycle
https://bigfix-ideas.hcltechsw.com/ideas/BFMCM-I-8 Add client management support for Realware HMT wearable headset Modern Client Management
https://bigfix-ideas.hcltechsw.com/ideas/BFMCLOUD-I-20 Have the Cloud plugin Portal pull in the allocated storage for a cloud provider e.g. Azure Multicloud
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-202 Enhance Windows Cumulative Update Fixlets to validate file versions (rather than just registry checks) Patch
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-201 Allow versioning of Fixlets and tasks Patch
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-200 Decentralized Patching - Device Owner Patching Patch
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-199 Chrome - Option to end task on Chrome EXE for update Patch
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-198 Superseded patches should have a link to the patch that supersedes it Patch
https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-197 Multiple data sources with Web Reports Patch
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-249 Enhance Client Deployment Mechanisms/Tool to support Single Sign On Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-248 Support relevance substitution/action parameters in BigFix-native powershell actions/scripts. Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-247 BigFix Client removal issued from client Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-246 SSA does not observe the “confirmation message” setting on actions taken in Console Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-245 SSA History view missing previous executions from same action ID Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-244 SSA Client - Ability to custom sort the History view Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-243 SSA client configuration option – set default “Category” Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-242 SSA Catalog view iconography confusing “Get” Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-241 SSA itself and “message box”, “Take Action” or “post-action” pop-up should support branding Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-240 Add Ability to Pause Policy Actions Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-239 SSA “message box” for action completed should self dismiss as ClientUI does Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-238 Mobile app for Remote control (lite web portal broker sessions) Platform
https://bigfix-ideas.hcltechsw.com/ideas/IDEACNCTNS-I-2104 Please allow a way for computers whose BigFix agent are installed using the plugin to ONLY show up ONCE in the console Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-237 We need to track more than just the first 6 IP addresses on a server. Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-236 Restart download after relay switch Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-235 Ability to have Internal Sync Server Platform
https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-234 Integrate performance monitors into Console/WebUI/API Platform
