In some cases you may have multiple relevance statements combined that can return user objects or sids (security identifiers), and it is useful to return only the unique set of them to then use in further relevance statements.
Example:
sids of (local users; users of (logged on users;current users) )
Not a very useful real world example, but a simple one.
Ideally, you would be able to get just the unique set of users, or the unique set of user sids from the above result.
But that doesn’t work:
Q: unique values of (local users; users of (logged on users;current users) )
E: The operator "unique values" is not defined.
Neither does this:
Q: unique values of sids of (local users; users of (logged on users;current users) )
This is an option to work around the lack of inspector:
sids of users whose(user id of it is contained by set of unique values of user ids of ( users of (logged on users;current users) ) )
This should work, but does not:
Q: (sids it) of (unique values of (it as string) of sids of (local users; users of (logged on users;current users) ))
E: The expression could not be evaluated: BAD SID - Revision: %23 SubAuthorityCount: %01 IdentifierAuthority: %00%00%00%00%0ff
( @strawgate has a solution to this particular method below )
CC: @AlanM
In the more general case, I want to be able to get unique values
or a unique set of almost everything in relevance.
