Hey Folks,
We’d like your input on priorities for what we do in the next couple releases of our
Security and Compliance Analytics module
Since we’re using an agile implementation methodology, we have the flexibility to plan a series of small incremental releases based on your input. An update would be available every 3-4 months and would introduce two or three new features. Of course the upgrade process for you would be seamless and delivered via fixlet (like today) so our hope is that you’d be able to readily adopt the release if you were interested in the feature set.
Here is a starter list of some things (but not all) we’ve heard. Please reply with your prioritization, and definitely add any of your own desired features to the list:
[ ]PDF export
[ ]Vulnerability reports from Patch content CVEs
[ ]Patch compliance and patch progress reports
[ ]Measured values polish (e.g. convert cryptic values to human-understandable terms)
[ ]Set report triggers and the event (e.g. email it to xxx@xxx.org)
[ ]Triggers based on time (e.g. once a week)
[ ]Triggers based on compliance results (e.g. when a group is than a certain % compliant)
[ ]Set data purging rules
Don’t be shy now. We need your input!
Thanks.
– Jeff
