This is the first action script that I have worked on, and I am having a few issues. Here is the code.
parameter "SAPVERSION" = "{version of regapp "saplogon.exe"}"
If {exists running application "saplogon.exe"}
dos MSG * There Is A Running Saplogon.exe Process
endif
Continue if {not exists running application "saplogon.exe"}
If {parameter "SAPVERSION" = "7100.3.13.1045"}
dos start \\plastipak.com\netlogon\sapinstall_00.bat
endif
dos MSG * END
I have the messages in there for testing, and they all come up in the debugger. This action runs 100% fine in the beta debugger that was on the bigfix site, but when I put this in a task the task ends up failing. I am guessing that I am missing something simple, and that the debugger is buggy at this time and not properly evaluating the action (although it shows everyhting as working).
Ok… here is my revised action script which currently works!
parameter "SAPV" = "{version of regapp "saplogon.exe"}"
endif
If {parameter "SAPV" < "}
dos MSG * Need Update
wait "\\ntapps03\sapinstsvr\Setup\NwSapSetup.exe" /NoDlg /Package="SAPGUIALL"
else If {parameter "SAPV" = "7100.3.13.1045"}
dos MSG * Current
endif
My next question is this… I want to use “if” statements to query if a computer is in a group in bigfix. Is this possible?
